New WOTTECH cams????
  • New WOTTECH cams????
    I was looking at the WOTTECH site and saw that there was new stuff arriving as well as some changes to thier new cams.
    Anyone know more about this?....Ben?
    P.S. Did my cam arrive yet?
    New cores are in and being checked. Will be ground this week. I hope to hear something definitive for a date (not like the last date they gave me but I knew it was bullshit anyway).
      Are there going to be any changes to the grind profiles. It seems like I remember reading something like that on the site.
      edit: any word on the new roller rockers?
        Nothing on the rockers. The new lobes are Comp Cams lobes, so anything in their master catalogue, specifically the SBC sizes, are going to be the new grind possibilities.
          Ohhhhhh... Your recieving a set of blanks. I though that you had ordered finished cams.
          In that case....... do you think that you could make alterations on my grind?
          I would like to see a slightly higher power-band since Ill be shifting at 7200 rpms. (maybe 6000 rpms "peak power" with flat curve if possible. nothing too crazy though since I can't go beyond .550 lift)
            I'm not ordering blanks, as I have no way to grind them. Comp ordered blanks for us and are doing the grind. I might be able to get it changed but I don't know for sure.
              Will these require bronze dist ring or stock?
                They will use the stock gear.
