'03+ Crane gold rockers?
  • '03+ Crane gold rockers?
    So anyone got a part number on them? Anyone else make them other then crane? Does something else cross over from another chevy?
    no to all those. Until scorpion has time to do our rockers, we are SOL.
      You could use ARP 8mm to 3/8" conversion studs but then I think your screwed for guide plates unless you bush them for 8mm studs. Or drill and tap your heads for 10mm to 3/8" conversion studs. Use gen II guide plates and then an aftermarket narrow body rocker arm with hardened pushrods. Slight LIM clearancing is required for most aluminum bodies rocker arms. Harland sharp has 1.65 ratio rocker arms but I have not seen anyone use them yet on a 660.
