  • 3400/350
    I was serching the forum but the info is somewhat scattered. Fora 3400/3500 what headgasket should I be using? Do the WOT-TECH gasket kit is good? or will I run into problems with it?
    Mike 60degree addict.
    You can actually use either since they are both .060" compressed height, difference is the bore in the gaskets, 3400 has 3.75" gasket bore, 3500 has 3.8" gasket bore. Some would argue the gasket bore should match the engine bore as close as possible, but the 3500 gaskets is what us RWD guys are using on the 3.4/3500's.
