Im thinking a Nitrous build is in order
  • Im thinking a Nitrous build is in order
    i looked around today and what i had for spare parts and this is what i came up with
    block, 3.1/3.4 crank,1 set of rods/3.1 pistons, a old 260 cam and lifters,a gen 2 top end and my other set of ported iron heads.
    i dont have a stock intake for the gen 2 stuff but i do have a custom manifold i built that clears the dizzy. it just needs to be finished
    i also have a wet nitrous setup that i will prolly never use on my turbo motor,its only good for upto 150 shot though.(simple soilinoid change and that can be upgraded to 200-300 shot)
    the 3.1 rwd motor was what 8.9-1 cr ?
    and with the gen 2 stuff it will work out to 11-1 or so
    im not all to familiar with high hp nitrous setups so im unsure of a low compression or high compression build would be in order ill have to look into that
    so i could prolly put this thing together with stuff i have laying around for 300 bucks or so by the time im done with bearings and gaskets.
    not sure though but its deff a very tempting lil side project to do since noone has really built a motor to abuse with nitrous before
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
    due eet. lol. deffinatly sounds like it would scream.
      how much do the 2.8 pistions pop out of the bore when put in a 3.1 crank???
        im thinking if its not much i could fly cut down a 2.8 pistion to reach a 9.5-1 or 10.0-1 cr
        they are pretty beeffy on the top
          anyone??
          i knwo the info was posted i just cant find it
