2.8 S10
  • 2.8 S10
    i have a 91 s10with a 2.8 and Im going to put headers,intake manifold, tb spacer and 400cfm throttle body so how much power do you think it will make
    maybe ~125 hp
    '86 Grand National
      If you have an s10 with tbi don't use the spacer,have the manifold bored for the 4.3 tbi [unless you don't feel comfortable removing/replacing the intake]use the 2.8 in in the 4.3 tb or it will run rich. To realize much benefit from the tb swap you will need a new cam,the crate cam with matching valve train from gm or the crane 260 and it will give you a noticeable gain and be ecm compatible.
