what cam and injectors should i use?
  • what cam and injectors should i use?
    im building a 3100 engine for boost, going with ross forged pistons, k1 technologies h beam rods, and top end...
    im just stuck deciding what i should use
    i plan on purchasing one of the turbo cams from wot-tech, but cant decide which one..
    my goal hp is 400 at the crank AT LEAST...
    thanks for the help
    Hi, just PM Ben, he can run simulations.
    I went with the 210/214 @ .506 lift (forget the grind #) with LS6 springs and new pushrods and Ben hooked me up like crazy and the engine runs like a top. This is with a blower though, shift RPM is around 6500.
    Highly recommend just telling him your vehicle weight, usage, desired rpm range...ect ect.. and he'll fix you up.
    I can't see a problem at all making 400HP and still being completly streetable. (if that's what you're after) ?
    grind # in my sig now.
    I like Ford Racing injectors, they are cheap on ebay for new ones, I got red tops 30# / hr, but you *might* need larger, mine aren't maxed out and I think I have 300+ at the wheels, my guess would be 330 HP at the wheels (just a guess)
      how do you get ahold of ben? whats his username
      Thanks
        SappySE107
