1995 Monte Downpipe/Exhuast Question
  • 1995 Monte Downpipe/Exhuast Question
    Alright Guys, I'm going with a down pipe and exhaust at the same time. I was wondering if the ZZP 3400 Downpipe with high flow cat would fit my cat-back, SLP Powerflow, or GMPP Cat-back(I Can't Decide), And my 3100 stock exhaust manifolds. I know the catback would fit because i checked at walkerexhaust.com same part numbers, different resonator placing.
    I can't wait for my car to sound like this!
    http://www.youtube.com/watch?v=FdSnYsKouCc
    Thanks Guys!
    ive got a zzp catless 2.5in. d.p. il sell you for 85$..been trying to get rid of it...went turbo...LMK when you find out if itll fit..
    00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
    99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
      boosted will it fit my 96 3100 gp? If so i will buy it if mobbdeep doesnt and pick it up..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
        is it Stainless steel? otherwise i don't want it. I live in Canada
          its mad eout of aluminized steel...it might..it might not fit oyur grand prix..i dont see why not...3100 and 3400 are the same platform...should bolt up..dont quote me though
            well i have a spare 3100 POS DP to match it up.. PM me you might have it sold
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
