what do you think? 1.6 rockers on 2.8
  • what do you think? 1.6 rockers on 2.8
    i have a set of roller 1.6 rockers laying around i was going to use on my 3400.. i decited not to use them. i do have an 86 fiero 2.8 that i was thinking about putting them on... or im putting them up on ebay
    do you think i would get any decent gains on the iron head 2.8? im thinkin not..
    It's like adding a cam that has very little changes compared to stock profile. Worth it in the end if you have them to install.
    Do it.
      You will notice it. I did on my S-10. You should feel it a little more on a light vehicle.
        Are they roller or ball/pivot? Ball/pivot from the 94-95 (some 96) 3100 are a direct drop in.
          there the crane cams full roller..
          wait. so i can use stock rockers from a 3100 and get 1.6?
            Yes. Early 3100(1994-96/97?) had stamped steel ball/pivot 1.6:1 rockers.
            Personally, I don't think the rockers would help the old 2.8L much. The intakes and heads are so restrictive that you would only see gains in the low-end. Most stock Fiero 2.8s loose steam at about 4500rpms.
            Its up to you though. Do it if you have nothing else to do and just want to experiment.
            -Joseph
              94-95 3100 got the ball/pivot. 96 heads had notches for roller rockers, but not all got roller, some still had ball/pivot. 97 was full roller no matter what IIRC. Brad posted the info once.
                well if i can get a full set of 1.6s at a jy for 20 bucks instead of using my $400 rockers on an engine i dont plan to keep i think i will do that if i ever decite to pull the valve covers lol..
                guess i gotta take pics..
                thanks for your input guys
