what size do i need?
  • what size do i need?
    iam dead set on getting hooker aero chamers on mr 1994 GP SE 3100. but i dont know what size inlet do i need. im using the stock sized piping....... is it 2''...... 2.25''
    also i was thinking of replacing my resonator with a glasspack also........ what are you thoughts on this............ and as always your responses are appriciated
    if you get 2.25" and it's too big the shop can make an adapter to fit.
    a glasspack will flow worse than the resonator, i'd remove it all together and put a piece of pipe in there. Replace the cat with a hi-flow while you have the chance.
