Help me choose injectors
  • #16
    It should be good on the 3500. But if you think about it its really stock size for the 3500.
    I think with a good tune on a 100% stock 3500, theres alot more power to be had then ~200hp.
    95 Beretta- Lg8 Daily Driver
    • #17
      I've been working on tuning a stock 3500 5 speed Cavalier, i started off with one of my 3400 tunes and with both engines using 24lb injectors i had to add a bit more fuel for PE mode and pull fuel for crusing (that basically means that it makes more power and is more eficient than the 3400).. I bet it's putting down atleast 210 at the wheels, should be good for high 13's easy.
      • #18
        So is my definition screwed up I use to scan or is my ECM really pulling fuel all the time and never adding with my intake/tb setup? Cause it's always pulling the BLMs down. So maybe that's correct and it needs less fuel cause the motor is under less load from making more power now?? With the new TB the car doesn't need to downshift on big hills, where before you'd keep giving it throttle and it would be slow then downshift. Now it pulls like nothing. When going WOT it pulls good in the gear its in before the trans has a chance to downshift too. Hell tonight I thought it was in first cause it was pulling so well until I gave it more throttle and it shifted to 1st then!! LOL
