Cam question
  • Cam question
    What do ya'll think of this cam for a 87 auto 4x4 blazer?
    Crane POWERMAX Cam and Lifter Kits Part Type: Camshaft and Lifter Kits Part Number: CRN-254122 Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-4,500 Intake Duration at 050 inch Lift: 204 Exhaust Duration at 050 inch Lift: 214 Duration at 050 inch Lift: 204 int./214 exh. Advertised Intake Duration: 264 Advertised Exhaust Duration: 274 Advertised Duration: 264 int./274 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.423 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.423 in. Valve Lift with Factory Rocker Arm Ratio: 0.423 int./0.423 exh. lift Lobe Separation (degrees): 109 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in.
    I suck at picking cams, just wanting a little more out of it. I DD it and the thing takes off like a slug and takes forever to get up to speed. I'm not looking to drag race it or trying to build something with gobs of low end just something to wake it up a bit.
    Mods so far include a k&n in an open 10 breather, coming soon: headers, 4.3 TB mod and later on a 3.4 as soon as I can find one.
    87 3.4 4x4 blazer
    If you want low end than the Comp Cams 252 Cam is the one you want.
    For a daily driver the Comp or Crane 260 cams are nice. The Crane 260 would be a better low end and flatter torque curve cam than the Comp 260 but the difference between the 2 is little. I would buy whatever one I could get cheaper.
      I can get the one I posted for $44 plus shipping (new on fleabay) is why I'm asking.
      87 3.4 4x4 blazer
        Its not the best cam but for $44 it may be worth it. It in not a horrible cam, it has a narrow torque peak but the lift numbers are descent.
          I have the comp 260 with good results. Altough my motor is quite a bit different. I have a 3.1 bottom end with a 3400 top end. With the cam, port matched lim, 3400 exaust manifolds, exaust and cold air intake it starts pulling hard at 3 grand, but has loads of low end torque for daily driving. Its got a bit of lope to it, but its still running off the stock chip with 5.0 injectors and an 01 fpr, so its rich as a bitch. Still waiting on a tune.....but im going to try the pre 99 fpr and see what that does for me. 3.1 injectors were much too small...........
