Alrighty, I've got my plan finally for which engine I want to get. I've axed the L67 completely off my list, partly because of difficulty of the swap compared to a 3400 and partially because of its brutal fuel economy. I mean, that tentative when it come to modding, but I have a feeling it won't be getting any better, at least the 60degree won't get too much worse. Besides, I'd rather reach my goal with a 60degree anyway. ENOUGH RAMBLING ALREADY:
So my goal is 240 crank horsepower, with roughly the same torque or more depending on what happens (really I'm looking to pull the same power numbers as a stock L67, but I'm hoping I can do it cheaper than the swap would be and do it N/A
So now its just weighing the pros and cons of two setups, and what you guys think about it.
SETUP 1:
Full 3400SFI
Custom Ported Heads
WOT-TECH Ported Manifolds (I may do these custom)
Comp Valve Springs
WOT-TECH Street Cam
S&S Headers
TCE 65MM TB
SETUP 2:
3400/3500 Hybrid
Custom Ported Heads
WOT-TECH Ported Manis (also may do custom)
S&S Headers
TCE 65MM TB
*Note: I think just to make this swap easy I will be using the 3400 UIM
I haven't got completely concrete prices but I have a feeling I will not be able to get a cam if I do the hybrid on my planned budget. I am hoping to get the engine and a tuner this summer and start working on it. It all depends on other costs though, I'm planning on doing body work this summer, which includes paint (though I will be doing that myself). I'm also planning on making a set of coilovers this summer if all goes well. However all in all my single greatest expense will be the tuner if I can't find something cheap.
Either way, what do you guys think?
SETUP 1:
Full 3400SFI
Custom Ported Heads
Comp Valve Springs
WOT-TECH Street Cam
S&S Headers
TCE 65MM TB
SETUP 2:
3400/3500 Hybrid
Custom Ported Heads
S&S Headers
TCE 65MM TB
