3.4 Head And Intake Swap
  • 3.4 Head And Intake Swap
    i have a 93 firebird with a 3.4 and heard about swapping to 3400 or 3500 heads and intake and wasnt realy sure what i would need from the doner moter for this to work with my 3.4 i heard i could get some more hp by running either of the setups i am hopeing its a bolt up deal
    Fitting under the 93 cowl might be a bit of an issue. The previous gen had more room.
    It's not really bolt up. I mean it bolts up but you gotta make other stuff work like accessory brackets etc.
      At least with '93 you have OBD1!
      With some fabrication skills, you can get the heads on there fairly easily. The stock brackets need some holes slotted or re-drilled, but they work. 3500 UIM won't fit, but the 3400 UIM bolts to the 3500 LIM, so you are good there. You need a three wire coolant sensor in the block, or tap the 3500 heads to accept the 3.4 sensor. You need a throttle cable from a 1995 GM truck, they are available from GM for $15. fuel rail from a 3400 will work. I may be forgetting a coupleof details, but this should get you started.
      Oh yeah - 3500 heads/gaskets and 3.4 pistons = 11.5:1 compression if you don't want to change pistons.
        ok cool but what throttle body do i use i heard the 3500 is fly by wire can i us emy 3.4 also wich injectors to use thanks for the help
          sorry thought of another q do the 3500 heads have roller rockers factory and if so wich pushrods do i need to use 3.4 3400 3500
            another q my pacesetter headers wont fit either will they
              I can't remember if the pacesetter headers have large enough primaries to fit the Gen3 heads - if they do, just slot the bolt holes to work with the Gen3 pattern.
              Pushrods are a debate when it comes to the 3.4 hybrids. Russel has been using stock Gen2 pushrods for years, but until I bolt a set on my motor an measure - we don't know if they are exactly the correct length (if they are short, max lift isan't being achieved). If you go to full rollers, you will have some adjustability though.
                3500 plenum won't fit but 3400 will and bolts up to the 3500 lower. So you would run a 3400 TB (56mm) on there.
                Yes 3500 are roller fulcrum. Pushrods no idea you'd need to measure and maybe get custom. pushrods.net I think is the place.
                  What about the 3.4 cam? I'm thinking of doing the same thing. Saw a complete 3500 for cheap. My 3.4 is out of the car and the cam change would be easy. Could I use the 3500 cam?
                    No. the 3500 cam is a roller, and the 3.4 is flat tappet.
                      How much differ. in power do you think there would be between the stock 3.4 f/t and the stock 3400 roller?
                        thanks for all the help guys
                          Are you serious??
                          I was thinking about doing a 3500 topend swap on my 3400, but Im going to be running boost soon also, so I dont know about having that much compression.....
                          What should I do?
                            3.4 = fbody iron head RWD engine. 3400= FWD engine. 3400 with 3500 heads will be less compression than a stock 3400 which is 9.6:1 or so. No worries.
                              IIRC 9.1:1 3500 heads, 3500 gaskets and 3400 pistons. I'll be changing to 3400 pistons when I put boost back on
