Oil Pan and timing cover
  • Oil Pan and timing cover
    Just a quick verify, but my 3100 Oil pan and timing cover are a direct bolt on to my 3400 if I am not mistaken. Feel free to chime in.
    Yes.
      Also both typical things to swap over to some 3400's when doing car specific swaps... I know I want to put a 3100 pan on my 04 3400 because then my A/C compressor will bolt to it and I'll have a low oil sensor again!
        Depending on the car the motor was in, the Timing Cover could have some small differences. Like the Timing Cover from a grand am, youll have to grind off the tab for a pulley to use in a W
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
          Same thing on a L-Body
            timing covers from a 3400 W- will not need to be modified to work in an older style W
            i did a Monte carlo 3400 engine to a 94 grand prix. the covers were interchangable
            94 Grand Prix
              Ok Im just swapping my 3100 pan and cover over to the other motor when Im done, thanks though.
                I have one. pm me if you want it.
                '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
                1/8 mile 9.72@75 mph, 2.0 60 foot
                  didnt have to anything except swap over a few pulleys, the flat for the ribbed pulley.
                  this was with the 05 3400 from the imapala into my 99 grand am.
                  99 Grand Am GT
                  1357 cam 227 233 .050 dur
                  515 515 lift 112 lsa
