newb
  • newb
    just want to know how to put 3400 heads top&bottom intake on a 2.8 s10 moter
    it can be done but you will have to convert to dis ignition system because there is no way to fit the distributer to the 3400 intake and i am not sure or this but i think that maybe you will need the ecu and wireing harness because of the dis convertion you will need a crank triger
    it has been done here so i am sure sombody will come in and tell you more details and maybe a step by step
      What he said.. Or build ur own carbureted intake making sure to give enough room for a distributor, if u plan on going to the dis system, and want carbureted, Electromotive makes an ignition system where the spark curve can be set
      Six-t-Six Motorsports
      2.8L Chevette Roadcar
      3.2L Acadian Racecar
        i beleave hes wanting to do like forced firebird or whatever. with the full fi conversion,
        get the computer out of an older model cavalier and convert to DIS
          Yeah, looks like it.. I shouldent have said anything
