This Year 3400
  • This Year 3400
    Planing on going stage 2 N/A
    My headz are shot, my pistons done for, and my block might be worth saving.
    currently .040 bored over stock on the cyl.'s
    Where do I start?
    What Im thinking......
    Stage 2 heads and cam from 60*store or milzy store
    keep the block go for .060 over but keep in mind I am currently .040 over and never over heated
    Purchase some Cast pistons I dont think I need Forged but what do I know
    Use the Valve train from my old headz such as; comp cam valve springs, and milzy push rods
    keep the ported and polished upper and lower intake
    keep the 65mm throttle body
    keep the 28# injectors
    keep the other guys headers
    basically Im trying to build the engine N/A to exceed my RSM S/C setup
    I have heard of stage 2 milzy stuff going 13.99 so they claim
    I have a more rounded range of performance mods than the guy running 13.99
    So guys I need some advice, Im doing this soon give me your thaughts please.
    What would you do?
    I thought you sold the car???? huh??
    worked 3500 heads, 3500 lim, your ported 3400 upper, or a 3500 upper, a hot cam, and a perfect tune you could make some good power. Cast pistons are fine.
      worked 3500 heads, 3500 lim, a 3500 upper, a hot cam, and a perfect tune you could make some good power.
      Sshhh! That's what I'm doing... don't tell anyone!
      -RUSH
        MMS stage 2 made 203 whp. Colin's 3400 made 222whp(with WOT-Tech street/strip heads and 1280 cam).
        Did you know that MMS stage 2 cam has more duration and lift than the 1280 cam yet the 1280 cam car made more HP? Add that with a WOT-tech ported 3400 lower and upper and you should be around 225ish whp with a 65mm TB!
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
          Get in line!
          Your local OBDII moderator
          2000 Grand Am GT w/ WOT parts
            Originally posted by sprucegagt View Post
            Get in line!
            Yeah, really! Me first me first me first me first!!!!!!! Almost have all my parts now. Spruce, hows your build looking?
              I would have a sonic test before you bored your engine out even more. For all you know your cylinder walls could be a little thicker than my 3400 or it could be thinner and you could be currently risking blowing your lower end.
