Right now I have a 2.8 and looking to put roller rockers on it. I would like to know with the stock cam what all else do I need to swap out. Also I'm pretty sure it will but will everything be good to swap over to the 3.4 if I ever find one. Like the push rods and springs if I got to get new ones. Its all going in a 87 auto/4x4 blazer. Also I'm already searching through 14+ pages trying to find the answer now.
2.8/3.4 roller rockers???
Assuming it's an iron head 2.8 that originally came in a Blazer, you've got a couple of options.
The Crane gold rockers for the 60ºV6 is the easiest bolt in. Or you can order the ARP metric to standard rocker studs and use SBC self aligning roller rockers.
These can be swapped over to either iron head or aluminum headed engines.Franz
1990 Z24-NA 3.1L
14.72 @ 92.24 MPH
14.89 @ 94.92 MPH
The boost is coming....
Franz is still alive!!!!!!Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Originally posted by XLR8ING View PostAssuming it's an iron head 2.8 that originally came in a Blazer, you've got a couple of options.
I have the Crane rockers on mine but knowing what I know now, buying the ARP stud kit and picking up a set of of Scorpion rockers is a much cheaper route to the same end. Unless our store still sells the Crane ones. I know they are a better price on this site than they were locally for me.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
So just to back up what I've read, with the 1.6 rockers I can just bolt them on (with the correct studs to convert it) and the stock push rods and springs will be fine with the stock cam.87 3.4 4x4 blazer
Originally posted by SappySE107 View PostScorpion sells narrow body roller rockers? Interesting. I still sell the cranes as well as the mod service to clear the lower intake on aluminum heads.
Originally posted by neo71665So just to back up what I've read, with the 1.6 rockers I can just bolt them on (with the correct studs to convert it) and the stock push rods and springs will be fine with the stock cam.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Ooops, sorry, got my rockers mixed up.
I should know better considering I have the Harland Sharp SBC rockers on my 3.1.
Thanks guys. I'm still kicking, just not as much lately.Franz
1990 Z24-NA 3.1L
14.72 @ 92.24 MPH
14.89 @ 94.92 MPH
Originally posted by neo71665 View PostSo just to back up what I've read, with the 1.6 rockers I can just bolt them on (with the correct studs to convert it) and the stock push rods and springs will be fine with the stock cam.
Why would the S-10's be different?Andy
I'm gonna be using new springs. I'm rebuilding the heads and my uncle has some rockers he got off ebay that were missing one out of the set (for a v. He gave them to me when I asked and they turned out to be crane golds but 1.6. I just wanted to make sure I didn't need any heavier springs or custom push rods cause I've already ordered both in the stock size. I did try to search but only come up with a ton of threads not addressing this.
Thanks87 3.4 4x4 blazer
You should get heavier springs. Not just new ones. The stock springs, even new, are hopelessly weak. I would install a set of Comp springs or GM Crate engine springs.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
oops, the gold roller rockers... thought you meant the crane roller tips. oh well..Andy
