Intake on my 3500!
  • #16
    Smart Choice
    • #17
      Yes if you can cut the bottom, fiberglass on a snout and run a large tube down to somewhere cool you should be golden. You could leave the snout that goes behind the headlight too. I doubt having the air come from 2 sources into the filter would cause turbulence to worry about.
      • #18
        Originally posted by PCGUY112887 View Post
        Ouch $200 for a box and I still have to move my battery and washer fluid... I think I'll just see about hacking up my stock box
        I have an oddysey race battery. It's the same size as a PCM. If you pick one of those up(around $100.00) then u should be able to fit a wizair. I'm going to do it after my engine swap.
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
        • #19
          Smaller than an Optima then? That sounds like 1/2 the size of one.
          • #20
            a lot smaller, the battery i believe ben is talking about is the pc680 which i plan to run in my car, it provides 680 CCA, not bad for such a small package
