3400 Topend and what ?
  • 3400 Topend and what ?
    Anything I should get with the 3400 topend[heads/intake]so I don't have to chase them down later,like bolts etc. It's going on 3.4 block [camaro].
    The TB... Metal heater core line that comes out of the LIM for fitting to the intake and modding to fit your car... Uhm.. t-stat neck? uhm fuel rail, injectors and FPR.. Valve covers...That's all I can think of now.
      3.4 can accomodate a 3500 top end,, but if you already have 3400 prts, then here is what I have found so far for a 3x00 top end in a 3rdgen fbody:
      Head bolts,
      Gaskets,
      TB,
      Throttle and trany cable for auto.,
      LIM bolts,
      UIM bolts,
      Upper heater hose,
      Modifying the top of the timing cover for t-stat housing,
      3400 top end will require piston change,
      Fuel hard lines modified or replaced with -an fittings,
      Fuel rail from a 3x00,
      FPR from a 3x00,
      Modify accy brackets to work, by enlongating holes/drilling new ones for 3.4 brackets to work(3x00 brackets won't work),
      Valve covers...
      That's it off the top of my head. What valvetrain components are you going to use?
        Thanks,I know it's kind of a dumb ? but that's why I hate buying something over the net,you don't have access to all those little items like you do at the jy.
          I agree, my fingers are crossed, this is the third crank I'm having sent. I hope this one passes my inspection for installation .
