FFP Pulley Oil Leak
  • FFP Pulley Oil Leak
    Has this been a problem for anyone? Oil leaking after a FFP pulley install? Wasn't their a newer Pulley version that was made to help prevent an oil leak somehow?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    Does yours have a steel outer insert? Did you change the seal when you installed it?
      they all leak IIRC.. they were machined slightly too small.
      Mine hasn't started yet but I'm sure it will...
        Theres a seal on the timing cover and a keyway on the crank. That keyway and the shaft NEED some sort of RTV. Thats how the factory seals them. If you dont put the RTV on and let it seal up ~1day before driving it, it will leak
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
          I had the same problem until dad helped me find the problem. That outer ring must be spotless and slightly scuffed before installing. If it's not or you have any kind of groove in it, then it will leak. A quick way to correct this is use some 400 wet/dry and a little elbow grease.
          Your local OBDII moderator
          2000 Grand Am GT w/ WOT parts
            My question is, why wasn't this noted a long time ago? I hate doing my seal once a year.
              best thing would be to get a speedy sleeve for it. for those not farmiliar with what that is, its a very thin (about 0.002" thick) sleeve that fits over the snout of the balancer. its designed to fix something that has a groove from were a seal rides. this would be the perfect fix for this.
