3400 RSM S/C - ALL Threads Combined
Fine you guys have convinced me. Soon as I put the MAF this week and get it tuned. Then I will work on intercooling my car. I have a ram air style hood. I was thinking I can move
my batery to the trunk. Cut out the ram air box(since its never been cut cause the batery was relocated for the S/C. So the batery is there instead if the air box.
So i put a small I/C there then the ram air would be shoved on top of it.
if i xan make it fit would it work
Originally posted by john_V63400 View PostFine you guys have convinced me. Soon as I put the MAF this week and get it tuned. Then I will work on intercooling my car. I have a ram air style hood. I was thinking I can move
A front mount intercooler would be better and less thinking to get proper flow and mounted.sigpicNew 2010 project (click image)
Originally posted by john_V63400 View Postyeah I see the point but won't the ram air cool the I/C just as well as a front mount. Its the same thing. Except with the intercooler there thier will be concentrated X amount of air. Resulting in more flow directly to the I/C since its concentrated
It's like when an electric fan breaks on a car. When up to speed, the air moving is enough to keep it cool, but as soon as you stop at a light, the temps start getting out of control. You have to imagine that the intercooler works exactly as a radiator, except instead of preventing overheating you are are prventing detonation.
Originally posted by john_V63400 View Postdamn why are u so smart
If you can learn the pricipals of internal combustion along forced induction, you will know what your engine needs, and how to have it perform in the manner you desire.
There are laws that machines have to follow, just like the physical world around us.
What size RSM Pulley are you running anyway...the 3 or the 2.5 and how is it that you are "Turning down the boost" on your setup.......just curious.........clue me in on this cause the only way I know the alter the boost on theis setup is to lower the puley size.........with the 3in pulley that the kit comes with 8 pounds.....with the 2.5in optional pulley 12-14 pounds max......so you must be running the 2.5 pulley............but how are you turning the boost either up or down.............do you have a dial?
Its a wiered thing, but Boost comes from RPMs. Im running the 2.5 pully
On a stock shifting GA 3400 you shift at 5650 I believe, thats 8psi of boost with the 2.5 pully.
I know because I changed the pully from 3 to 2.5 and saw a increase of maybe 1 psi. Around 7-8 with the 3 and 8-9 with the 2.5
I was very dissapointed.
i wasnt able to see 14 psi boost until i recieved my HP tunerssoftware and highered my Redline.
The higher I rev the more boost I get.
You must Rev above 6,000 RPMs on the 2.5 pully to get at least 12 psi
Im shifting at 6100 I beleive and Im getting around 12psi
Ive shifted at 6700 once or twice and got as high as 15 psi
So I adjust my boost acording to RPM.
That is why I want a much smaller pully so can get higher bost at lower RPMs
man, i hope you've upgraded the valvesprings.. stock 3400's won't take that RPM for long..
Where did you get the 2.5 pulley....did you have it made or did you get raped by Z-spec?..............I want one but will not pay their inflated prices....do you hacve a source...also what gator back belt # are you using with the 2.5 puley and last but not least what MAF are you using stock or LS1?
Chris
Originally posted by john_V63400 View PostIts a wiered thing, but Boost comes from RPMs. Im running the 2.5 pully
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
