s&s header fitment question
  • s&s header fitment question
    Hello this is my first post here.
    I was wondering if anyone could tell me if the s&s headers will fit a 1999 N body malibu. I currently have a intake , 62mm throttle body , ported upper and lower intake manifolds from 60 degree store : ) - MP racing tune , billet crank pully , billet and polyurethane front tranny mount and 2 1/4 custom exhaust.
    thank you for your time and it's good to be a member here.
    Welcome...................
    what engine does your Bu have?
      99 Malibu should have the 3100, and most likely the small port version (does the plenum have lines cast into it?). Considering the headers were designed for N-bodies, and I think 99+ (possibly 00+), they should fit no problem. Best bet would be to just verify any firewall and downpipe routing differences between your car and a 00+ Malibu, GA, Alero.
        It did have the small port intake manifolds stock. But , as i said above i got a ported set of large ports. Does anyone here know if there is a diff in the routing for the downpipe? Any help on this would be very appreciated.
          but the heads are still small port correct?
          Lots of mods cost lots of $$
          http://www.cardomain.com/ride/2598719/1
            Yes, the heads are still stock. I plan to do heads and a cam later on. The heads and cam were going to be my last mod. So , the headers will not fit otherwise? Or would not be worthwhile until heads and cam? Or just won't fit plain and simple?
              Well mine fit with help of a sawsall, hammer, welder and lots of time... 4-days IIRC.
              As long as you stick with the 3x00 style motor the headers will fit the heads all the way up to 05. I have 04 3500 heads on mine.
                Their site lists 99 + grandam/malibu/alero for the downpipe, I'm guessing the header is the same. Email them?
                  there both n body cars so they should just slide right in.
                  99 Grand Am GT
                  1357 cam 227 233 .050 dur
                  515 515 lift 112 lsa
                    will those headers fit a 96-98 n body grand am?
