What belt size with UD pulley
  • What belt size with UD pulley
    I've got the FFP underdrive crank pulley and was wondering what belt size is the right size if im running the alt, p/s,w.pump, tensioner and crank pulley setup only with out any idlers.
    Thanks.
    1" shorter then stock size
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
      Do you have a part number or anything? I've heard of using a 1/2" shorter belt and so many other differences.
        Stock belt, napa part number 25-060710. The belt you need is napa part number 25-060695. Its about 1.5" smaller. The only other size you could use would be part number 25-060705, but thats only .3" smaller than the 25-060710
        350/NV3500 5spd
          may sound weird but, on my 3.1 i used the stock belt as works just fine. some pulley on my 04 3400 needed a 1" shorter belt. -shrug-
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
