Solid homemade dogbone mount?
  • Solid homemade dogbone mount?
    Hey,i am thinking about taking a piece of square stock (aluminium or steel) the same width as the stock one,and drill two holes through it.Then just use the stock bolts and bolt it on.The i would either get an upper insert or fill the mount with jb weld.What do you people think of this idea?Trav
    You will get a lot more engine noise/vibration transmitted into the car.
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      I dont care about the vibrations.I just want to know if it will create any problems with the drivetrain or anything. Trav
        No it wont ruin anything. And yes you can just use square bar stock. You will feel more vibration but it is not too bad. It does help reduce wheel hop alot.
          So in other word you want to replace the dogbone with a solid piece of metal directly bolted from the engine to the dogbone mount? I had an 88 Celebrity that for some reason use to eat up the rubber in those mounts every 6 months or so. I did something similar and 3 days later the head broke right where the mount bolted on, and it had the 2.5l 4 banger (less than 100HP). Maybe I had something else wrong or maybe I just had bad luck. I wasn't exactly easy on the car when I drove it..
            i have a solid dogbone trans mount i made out of square tube, worked really good. i didnt notice anymore vibration for some reason...
              I used the stock z24 tranny dogbone, took out the rubber, and put in Poly inserts(fiero torque strut bushings), worked great, no noticeable increase in vibrations.
              -=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
              14.99@91.33mph
                i put poly bushings in my stock dogbone and it was an improvment, however not enough of one. a couple weeks later i ended up welding my engine mounts solid.
