3500 Pistons
  • 3500 Pistons
    At the risk of sounding like a complete moron [don't know anything about the 3500]can the 3500 pistons be used in a 3.4 ironblock.
    Only if you overbore it. You asked the question suggesting you don't know, you shouldn't be penilized for that or made to sound like a moron. All of the non VVT non DOHC 60 degree V6 engines 3.5 down to 3.1 have the same stroke and differ by bore size.
      Actually, its the opposite, same bore but different stroke (for 2.8 and 3.1 at least)
      1993 Chevrolet Cavalier Z24
      3400 Turbocharged Intercooled
      MS3 v3.57+MS3X
        I only mentioned the 3.5 to 3.1 because they have the same stroke also and without a significant change in some parameter you can't use the pistons but correct the 3.1 has the same bore however as stated the 3.5 to 3.1 differ by bore size.
          I just checked the specs: 3500/94mm and 3.4/92mm bores,don't know piston pin location.I'm wondering if the 3500 pistons could be used in a 3.4 ironblock and what the compression would be ?
            Only with the complete rotating assembly because the 3.5 has longer rods than the 3.4 also I'm not sure if the 3.4 block will need clearancing since the rod big end is larger along with the crank pins on the 3.5.
            And then there is the overbore you would need.
              Wrist pin hight has been moved up, according to Whitelighting, also teh longer rod would indicate this to be as well, 5.9" to 5.7" The big end is larger but I don't believe the center point offset would be .2". But that will need to be verified, I don't recall how much larger the rod journals are in the 3500.
                2.248" is the rod journal diameter the bore is 2.375" so there maybe a possibility it will interfere with the 3.4 block rails if they are not already relieved.
                  What about the 3500 piston on the 3.4 rod,how much would that drop compression ?
