3.1 mpfi
  • 3.1 mpfi
    hay is there a way to get 200 hp in this i want a 6 cyc not a 4 cylinder (90 beretta) would it take nos or boost or both or super charger any ideas?!
    Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
    yes there is but not cheep
      will a 3.1 take a 100 shot of nos lol
        maybe cpl time but to run safely numerous time a50 shot at most wont hurt
          3.1 MPFI
          I will vouch for the fact that it is not cheap to get 200 HP NA out of a 3.1 MPFI. I already have $2,000 into my built shortblock, and it will probably be another $1,500 for heads and intakes. If you are on a budget, and you want alot of power, a 3.1 MPFI build-up is not the way to go. This is coming from someone who really likes my 3.1 MPFI, and have since I bought my Sunbird new. I am just realistic in accepting it's limitations. I know that if I get 200 HP at the crank I'll be thrilled, but I will be maxed out. Then if I want more power, I will need to convert the top-end to a hybrid.
          Joe Morgan
          bracketracer
          '93 Sunbird SE 3.1/5-speed 14.869 @ 90.96 Heavily Modded
          '00 Grand Prix GTP Sedan 13.689 @ 100.97 Lightly Modded
          '09 G8 GXP Manual Trans 13.166 @ 106.47 BONE STOCK
            80shot is max I could go on a dry system, if you want to go higher you need to go wet.
            I ran about a 90 dry on mine and it killed a piston.
            I modify stuff
