Need intake manifold 3400
  • Need intake manifold 3400
    I need a 96-98 3400 lower and upper intake manifold. i also need a 3400 tb to go with it. does anyone have these parts? or can anyone get them for me? the closest one i found was 50 miles away, i checked the junkyards around here and found nothing.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    Ask sappy for a TB, he will probably sell you the body and the plate for cheap, and then you can take apart your 52mm 3100 one, and re-assemble it into the 3400 56mm one.
    Or if you want a complete one just check out www.car-part.com you can find intake manifolds there too. I got a lower shipped for $55 from a place on there. Just find a cheap place, call and they will ship it to you.
      kewl thanks
      1996 Beretta
      3100 SFI TURBO
        if you dont get the throtle body from him i can sell you the parts needed.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
