How dentrimental to performance/economy is..
  • How dentrimental to performance/economy is..
    running with the TPS disconnected? Ya. Because it's been. For about a month :irk: Man I'm pissed. The TPS is shot, and the car wont start w/ it plugged in. And I guess one day I forgot it's unplugged. THIS is why my car has been running shitty. Oooooh boy you guys dont know how pissed I am! But is this why on highway miles I could only pull in 20mpg, 3/4 tank only gets me 100 miles, give or take? And why my car is sluggish, poor idle etc?
    Thanks,
    Matt
    '93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
    I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
    camaromanmatt@yahoo.com
    Yeah, the cars computer doesn't know how much throttle your commanding it to give. I'm pretty sure there is some kind of default fueling table the car goes to when some sensors are acting up. Makes the car run really rich, so a new TPS would probably fix your problem.
      Ok that's what I was figuring The car idles at 3k when cold, and in order to get the idle back down ya have to shut the car down (after it's reading Warm) and start it right back up, and even then it has a nasty hesitation on takeoff and seems to be running rich as a mofo.
        Dude ya, lol that will fix a lot of your problems. My car in sub 0 weather idles at like barely even 1k on startup...
          Ooooh Boooy. Yep deffinently gonna fix this problem on pay day lol. It looks like the repair is a cinch... is this so?
            Should be a simple remove and replace. I can't remember if it's torx or hex bolts. With a new TPS your car will know how far open the throttle is, so yeah it's gonna drive a lot better.
              you can do it with the tb on the intake, but you need a little torx bit with the mini wrench/wratchet, i got my kit from candian tire
              sorry cant find a pic, looks like a mini wrench with a hole that wratchets and fits a bit
              anyways, make sure if you get a tps that has elongated holes(adjsutable) that you check your manual and make sure its at what the manual says for volts @ closed, like i mentioned in one of your other threads
                How...after replacement
                After you change the throttle position sensor, it would be a good idea to do what they call a voltage sweep.Thats done with a scan tool or a volt meter hooked to the blue wire and the black wire on the thottle sensor circuit if that fits your application.1.verifiy closed throttle voltage then verify with a sweep of the throttle completely to check wot voltage, when done slowly it can also define a glitch in a sensor.The reference voltage is about 5 volts.The reason for this is not nessasarily to test the sensor but to verify it is properly installed, I have seen this simple mistake cause grief in the past.
                  Torx
                  I am thinking I will just take the damn IAC off so I can get to the TPS easier. Otherwise I foresee myself getting VERY angered and not finishing the job. But there's no way to "adjust" the TPS right? Just bolting it in, hooking it up, and hoping it works?
                  How could it be installed wrong?
                    elongated holes
                      Thanks all! I fixed that beotch up yesterday, and man is the car aweome now! I cant vouch for economy yet, as my tank is and was still empty, but I will let ya's know after i fill it up this time! Thanks again for the awesome running car!
