how do u disable the speed limter on 3100?
  • how do u disable the speed limter on 3100?
    I have a 96 beretta, 8.8 spark plug wires, no cat or resinator with a flowmaster, and a cai. this car shuts off at 106. does anyone know how to disable the speed limter. I will take the ecu aout and mod if i have to. i just want that thing disabled.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    why? you run high 15's in the 1/4 so whats that....85mph?
    i dont see a purpose other than street racing which is gay.
      i hit around 90 and im goin to put a 62mm throttle body on which will nock me down to low 15s, then a programmer, and soon a s/c along with fuel injectors. it will run low 14s easy. now i might not not hit 106 but i dont want it there anyway.
      1996 Beretta
      3100 SFI TURBO
        Your not going to gain anything from just a larger TB. You need manifold work to even think about seeing a difference. Even then, you won't all of a sudden run low 15's.
        To disable your speed limiter, you will need a DHP Powrtuner or something similar.
        SpudFiles
        Theopia
        Enjoy life online.
          Small port 3100's are nice, but can't compete with the large port stuff or the 3500 stuff out now.
          A DHP will allow you to tune for boost and remove the speed limiter. But please be careful/safe, don't push the limit of your tires either.
            hu, my 95 beretta will run too 118 mph before it shuts off, this was at a track day i was able to attened at california speedway, i really don't recommend anything over 95 on an open freeway, plus if your busted over 100 it'ss up to the officer to impond the car for 30 days and take you to jail or give you a major fine. at least in ca.
              If you plan on running around over 100 on the highway, you best prepare to outrun that cop as well.
              SpudFiles
              Theopia
              Enjoy life online.
                speed limiters are in place to keep you from exeeding the tire rating and the suspention. i have driven my car with decent stock suspention and at 150kph (90mph) the thing was floating very bad and i wasnt about to go faster. now with everything new in my suspention (kyb struts, urethane bushings, sprint springs, addco swaybars) and some decent brakes, i would consider trying for 200km/h (im running stand alone), but id never do it on public roads.
                unless you have a track that allows you to get to speeds in excess of your limiter, and you have suspention, brakes, wheels and tires that will handle the speeds, please dont disable your limiter.
                  Where can i get a dhp?
                  1996 Beretta
                  3100 SFI TURBO
                    google it!!!!!
                    and you car will never hit low 14's with a stock 3100 and 4t60e... your smoking too much crack
                      ...and put your cat back in you polluter! lol, no need to run without it on a street car. You can get a high flow cat for under $100 and it's like a 2hp difference.
                      You can order a powrtuner from partsforyourcar.com. Be prepared to do some learning though. It will let you remove the speed governor as well as tune everything else you need to make it run well on boost or NA. If you really plan on driving that fast though, I recommend you completely mod the suspension and brakes first. Every try a panic stop from 110mph? Please be safe and be smart.
                      '97 Grand Prix GT 3800 (sold)
                      Gotta love boost!
                        well i ran a 15.6 at 89, so i dont see how u are going over 90 with the high 15s, and yah look at a 3400 swap and it will help alot more than the 3100 could, base line is better, and the ability to tune it for more power, and use alot of the parts that the store offers on here is another benefit
                        and yah NOx FTL, but the people over the north pole live with it...lol
                          well on drag times there is a 96 beretta that runs a 15.2, it has all the normal upgrades like exhaust, cai, wires, and plugs. but then it has a 62mm tb with a 3400 intake manifold. so thats what im looking at for a start. but i plan to s/c it eventually......and thanks for the link ill take a look.
                          1996 Beretta
                          3100 SFI TURBO
                            *cough cough*PCM*cough cough*. You need a tuner. but the speed limiter is there for a reason...you should make sure you have damn good tires and brakes before you set the speed limiter higher(which is what you really want to do). Do you know what happens to cars when they crash at 150+mph? See I live around lots of country roads and no tracks and it maybe easy to speed BUT it is unnecessary and dangerous because while you may be going 120+...It doesnt take much to loose control. Street Racing=Bad. Parking Lot Parties=Good. Also removing the speed limitter doesnt add hp. Just a thought dont take offense.
                            Originally posted by wozxx...{is 92 mph in a school zone illegal?}
                            I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
                              i know that it is unsafe and i will use caution. i just dont like 106mph i did 120 in my old beretta and had no problems, i have 245/45/R17 dunlops ready to go on my rims.
                              1996 Beretta
                              3100 SFI TURBO
