3500 ffp trigger
  • #16
    hua?
    my halfshaft and rear mount bolted right up... after a little adjusting with a big hammer, pry bar, dye grinder and a 1/2" drill bit...
    sounds like you and i work the same....lol
    • #17
      hua?
      I'm getting a '94 Jackshaft and don't want to modify anything and the adaptor plate will take about 20 minutes to make!
      • #18
        has anyone inspected the ffp pulley to make sure they are all drilled the same.. i just want to make sure the bolt holes are all in the exact same place..
        • #19
          They looked to be. When i had my pully on the engine and the trigger wheel lined up to the holes the notches lined up with ~TDC on each cyl...
          i'll know for sure when the new wheel gets here and i can bolt it up. the CPS can be adjusted quite a bit to compensate as well...
          • #20
            yeah .. i just want to make sure that the pulleys are all the same..
