Just thought i'd post up what they had to offer.
Currently they have 7 more solid roller cores for the 3x00 P/N 259356
they are listed for the '97+ 3100/3400 so you guys with the new cam trigger might be screwed. I'm not using the cam sensor so you guys have fun figuring that out.
These are the avaliable lobe profiles you can choose:
Duration @ .050/ Lobe Lift-Valve Lift with 1.6 rocker
238/.386-.617
238/.378-.604
242/.373-.596
247/.372-.595
238/.365-.584
234/.360-.576
234/.359-.574
238/.337-.539
Knowing max lift with LS6 springs on stock heads is roughly .560 I opted for the last option, if you have the spring seats cut deeper you can go with a much higher lift as long as the valve dosen't kiss the piston. lol
for the record, my cam is a single pattern .539 lift/238° duration 110 LSA 106 IC
Total cost is $404 + ~$12 for shipping.
Cheaper than Milzy's cams and Crane don't BS around.. he said i might have it in my hands before Friday.
238/.386-.617
238/.378-.604
242/.373-.596
247/.372-.595
238/.365-.584
234/.360-.576
234/.359-.574
238/.337-.539
