This application nis for a fiero with an iron head ohv V6. Just wondering who has has done it and how? i know about the guy with it over the rear exhaust manifold in a fiero and the guy with the beretta. Just trying to see if anybody has done it in a fiero? Or has any tips.
mounting an m90 on 60*V6 fiero
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.Tags: None
Originally posted by bjornmk1 View Postwell I am sc-ing mine with a ford m90.
it is going where my airco pump used to be.
doing that you'l need a relocator kit for the oilfilter.
I shortened the snout of my sc-er to get the fitment I need.
that way it wont suffer from the heat of the exhaust as much
as the set up in the picture.
I'm aiming at 240-250whp at aprox. 10-12psi.
ported the alu heads an manifolds.
350cc fuel injectors.
audi s4 intercooler.
what is yours going to be like
BClean Feet Pet Clean Up
I planned on having a bracket made so i can run it in in place of my old a/c compressor. I will be forging my motor this spring then i hope to build this system early this summer. I hope to run like 10-12psi with an extra kick from my nitrous system. I'm trying to get close to 400whpClean Feet Pet Clean Up
that's what it is starting to look like. Parts are cheaper for the super but the installation would be easier for the turbo.Clean Feet Pet Clean Up
don't forget that with a turbo you'll also need a oil feed line.
that's extra work compaired to a sc.
plus a turbo will heat up your engine oil compairde to a sc. so
chances are you'll also need some sort of oilcooler
good luck.
Bnothing's impossible-it's just a mindset
Even with the "extra" work of oil feed and return lines, and possibly an oil cooler, the turbo is still quite a bit more effcient than an SC, and also easier to control. With the use of the wastegate, over all boost can be controlled, through different parameters.
For example, if you find traction in first gear is lacking, you can set-up a waste gate system that limits boost in first gear, allowing you to hook up before applying maximum power.
Also if you would rather have two settings for overall boost, like one for cruising and one for racing, easily done.
I wouldn't even want to try an develope a system to do the same thing on an SC.
I have not given up on the m90 idea just yet. Just gonna take some research.
I understand the point of a turbo's efficiency, but just because it CAN be efficient doesn't mean it is.
Actually a turbo is harder to control because you need more equipment and that means more money. A turbo is controlled by "valves" and a supercharger is controlled by a crank. So the only way to over rev a super is to over rev the motor...but a turbo can over spin if a valve sticks open or shut. I also don't want to sit in my car for 10mins waiting for the oil to cool down. I also like the idea of no having extra heat in my oil.
I will try this until I absolutely can't figure a way to do it.Clean Feet Pet Clean Up
say fivepoint,were'nt you looking for forged pistons?
I dont know if you guys have ford cosworths in the states..
but I used those for my build,they are 3.57 bore size and have the same compressionheight as the 2.8 (alu head)
and can be used for iron heads as well by turning them down by
0.2mm.
but you would only be able to use your 2.8 crank..
and not a 3.1 crank
just a thought.
bjornnothing's impossible-it's just a mindset
yeah I am looking for forged slugs and yes cosworth is here as well. Those would work pretty good in a 3.4. Do they have the same hieght as a iron head 2.8 or an aluminum head 3.X? Do you have them in? Didn't you say they were for an escort? Details please?Clean Feet Pet Clean Up
yeah..escort and sierra.
st.size is 90.82mm bore..so oversize might just get you there with a
3.4 engine.
and yes,they will have the same compr.height as a 2.8L iron head
if you turn them on a lathe for 0.2mm.
this is not needed at the alu head engine..there they would be just fine.
even the piston pinn is out of center..just like the pistons in the 60/v6
only by 0.5mm more than ours
main advantage:they are forged and reasonably cheap over here.
