camshaft
  • camshaft
    i have a 91 corsica with a 3.1 and a 3speed auto what would be the best camshaft for it it will be driven everyday so i dont want to get to crazy with it. will the x-11 cam work and will it give a performance increase? i'm thinking
    about doing the 3400 top end swap if i do this i want to put a beter cam in it.
    thanks lee
    since you are doing the swap, and don't want to get crazy, i'd go with the Crane Cams H260. i eventually will be doing the swap too but either will do the H272 or convert to roller. the 260 will give you a nice overall gain, especially with the swap. don't waste your time with the X-11 cam. the H260 would be great weather you swap or not.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
      research these two cams:
      Crane 272
      Crane 260
      I'm using the 272 for my 3.4L build, but my build is going to be pretty wild.
      I believe that if you want a little more oompf but you're not going heavily modified then choose the crane 260.
        yeah, if you aren't going to do a hybrid swap then the 260 will be the best choice. if you are hybriding, then the 272 will be good. if a daily driver, opt for the smaller cam. it will give you more bottom to mid range torque and better mileage.
        Andy
