Fuel issues
  • Fuel issues
    I built a 2.8 liter for my 86 fiero gt and toatlly forgot about the fuel system untill i fired it up and heard the telltail sine of a backfire through the intake under load so i pulled a plug and found them to be white with a nice blueing of the electrode. so to make a long story short does anybody know where to get my car tuned in MI? and i dont whant to spend 1500 on a haltech ecu
    What part of MI? I'm not sure how close Ben is to you (probably not very), but I'm sure he'd be willing to help if he can.
      reply
      oakland county 50miles west of detroit
        Hmm... might only be ~3hrs for him. But I'll let him make the decision.
          thanks man I can also trailler the car
            I can't do anything to the fiero ecm.
              Hmm, yeah, I forgot that small detail.
              There might be a few others on here that might be able to help you out. Or try looking over on realfierotech.com cause I'm sure someone over there could help out.
                thanks guys for the info but it looks like im buying a Haltech ECU
                  if it is backfiring maybe you have a timign issue or a plugwire is on the wrong cylinder. YOu ever consider that? Probably not.
                    Hey Shaun ever consider its not the plug wires or timming... Probly not....
                      maybe its running lean due to 10.5 to 1 compression fully ported and polished heads and intake (upper middle lower plenums) bigger valves and throttle body??? hmmmmm ever consider that probly not
                        Why not use MegaSquirt on the thing? Definitely cheaper than $1500.
                          backfiring through the intake is a sure sign of it being lean.
                          there are other options without going haltech. i run a megasquirt ecu in my car, im quite happy so far. an assembled ecm can be had for around $400. another option would be to head to this site http://www.fierohut.com/ and e-mail the guy about a chip. you can give him your engine specs and he can get you a chip done. he is in vancouver bc though, so shipping might take a bit.
                            whats a mega squirt?
                              What is a Mega-Squirt
