Are there any gotchas on the 3100?
  • Are there any gotchas on the 3100?
    I have our M 3100 ready to go back together. New pistons have been fitted to a professionally bored .5mm OVER and honed block and professionally mounted on rods. The block was decked .006 and the heads cut .008.
    Crank was cut .010
    I have assembled many engines but this is my first 60v6.
    If anyone out there has totally assembled one recently. are there any issues I should be aware of?
    Appears to be a simple assembly unless I am overlooking something.
    If you've put together a smallblock you've put together a 660. Its all the same shit.
    Just use a damn torque wrench.
      its pretty simple. its amazing how much it goes together like a sbc.
      basicly, as long as your machinist did his job, it should fall right together.
        if they still use an o-ring in the rear main bearing for the oil passage, dont forget that, or your not gonna have enough pressure.
          get the new updated lower intake bolts from GM.
          Stephanie
          92 GTZ ~SupermoddedW41GTZ~
