Hey, I haven't posted for awhile, but I guess i haven't had any problems on my car either. But i do read posts everyday, just to soak in more knowledge. Here's the thing, I was going to have some time to play around with my car this weekend, and I'm wondering if it wasn't a bad idea to swap out that oil pump drive seal since mine hasn't been switched yet, that I know of. My car "weeps" oil, but never enough to add any between changes. Someone said it looks like a main seal, but I need to look at it myself to know for sure. What do you think?
Just a question...
To get right out you have to take the intake off. So you will need thoes gaskets aswell. If you do it change the o-ring and also add a SBC distributor drive gasket to it aswell.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Hey, I actually tackled the little oil problem last night since I didn't have to work, and it went easier than I thought it would, and I didn't have to remove the intake either. I looked at that one instruction posted a few days ago that told of how to do it. I just skimmed it and neglected to print it out or anything. Well, said and done, When I got to the piece itself, the O-ring didn't really look bad, but I replaced it anyway. Also, when putting it back together, I realized that when I had removed it, it wasn't seated all the way down. It was popped up about an 1/8 inch and bolted on like that, as far as I remember. anyway, I put everything together, let the fuel pump prime a few times, and she fired right up without any problems, and so far no more oil leaking out that I can tell. Thanks for the help. I have more questions later.
