i really need some help!
  • i really need some help!
    my wife has a 96 olds ciera SL with the 3.1. one thing i need ot know how to do, is change to air filter. i dont have a clue how to get the housing off to get to the air filter. i dont see any clips or screws or anything. any help would be great! thanks again!
    There should be 3-4 screws on the edge of the housing. I've had my airbox out for so long I can't remember exactly what they look like or if they are hidden in any way. I'll see if I can't find a pic or something that might help out.
      a pic would be great. i have looked and the screws must be hidden. i just put an intake on my 2003 alero 3.4 without troubles and now i feel dumb cause i cant figure this out.
        Is it the 3100 or the striaght 3.1L MPFI?
        If its the MPFI, I know for a fact that there should be four screws (one on each side) of the box (unless they changed it from 92 and 96). Easiest thing to do is also disconnect the air hose (make sure nothing goes down it though that wont be good)
        If it is a 3.1L MPFI, i can snap one for you. Just let me know.
        John
        John Barbieri
        1992 Chevy Lumina 3.1L Sedan.
        Host of the 60DegreeV6 and W-Body Chatrooms for IRC.
        server: barbieri.dyndns.org
        port: 6667
        rooms: #60v6 and #w-body
          John
          He said it was a 96, so its a 3100
          Robby Whitesell
          2006 Pontiac G6 GT
          1985 Toyota Pickup DLX
            John
            Give me a break, im still learning He only said 3.1, so id thought I give it a try. Looks like someone else has to do this then
            John
            John Barbieri
            port: 6667
              Super easy. You should have the ROUND airbox with the air duct that goes to the engine ON TOP OF THE BOX. If that is the one that you have, then remove the airduct from the top of the airbox (should be just a clamp that unscrews with a screwdriver). Once you get the duct off, there should be a WINGNUT under the duct that holds the lid down (you can't see the wingnut, or any other way to get the filter out without removing the duct from the top of the box. Once that is out of the way, the nut should be right there. Just remove the nut, and the top comes right off).
              Taylor
              1998 Lincoln Mark VIII
