Tappet tick and maybe more. No history bought used.
Runs quiet for 30 sec then ticks. Shorting cylinders loaded and unloaded does not make rod knocks.
Thick 20W50 not much help. Full power and good idle.
No warning lite but I need to do pressure check to be sure of oil status.
Somebody says oil pump is weak causing oil starvation to lifters; maybe too much bearing clearance. Maybe clogged gallery.
I bought a low mileage replacement engine rather than experiment with oil pan removal.
Nonetheless, any theory from friends?
