Can someone tell me what this is called and how I
  • Can someone tell me what this is called and how I
    Thanks!
    Looks the the tube for the PCV.
      Do I pull the metal out of the ends or buy the whole thing? I suppose I should just bring it into a parts supply...
        Thanks btw...
          The metal canister on the end is the actual PCV. Wouldn't hurt to replace that as well since its looking kind of rough.
            Ok will do. Thanks!
              Is it a bad idea to reuse the plastic gaskets that came off with the upper intake manifold?
                They are completely intact
                  I reuse upper intake gaskets all the time. But they are usually really cheap to replace if unsure of condition.
                  '86 Fiero, 3500, 4-speed
                    Thank you.
