LX9 to ODB1 conversion
  • LX9 to ODB1 conversion
    With Dave's counsel I have been preparing an LX9 to go into an Isuzu P'up. I got the wiring harness from a '94 Cav with the ECM(?) that was in the engine bay. After trying to sort out what wires were needed and what is not, I found that the ECM I needed was inside the Cav, not in the engine bay. Also, I need help in deciphering the coding to terminals on the info sheet from I have from V6Z24 with components, wire colors, etc. The ECM has internal numbers (C1, C2, C3) on the 'inside' and wire terminal ID's adjoining on the outside. Can someone tell me what they mean? I have traced one of the wires from the Ignition Module out and it goes through a molded bulkhead into the dashboard(?) of the Cav., not to the ECM in the engine bay. A little help, please.
    Lilredtruck
