86 fiero gt
  • 86 fiero gt
    im not quite shure where to post this, so its going here. i have an 86 fiero gt with a 2.8l stock engine. i blew a freeze plug on the right side (when standing on drivers side looking towards the pass side). what is the easiest way to replace it (preferably without dropping the engine). thanks much.
    They sell freeze plugs at the parts store that slip in and you tighten a nut down to expand it into the bore. Works similar to the block heaters that go in the freeze plug hole. Remove old pieces, clean/sand bore, install plug and tighten.
