no gas pedal???
  • no gas pedal???
    ok when i push my gas pedal more than a quarter f the way down my truck jumps and wont go anywhere!!! if i push the pedal all the way down it bauges down and acts like its gonna die!! what should i do? Any suggestions on what it could be?
    I'll blindly guess that you have a bad throttle position sensor.
    You'll get better answers if you specify:
    year
    make
    model
    engine size
    auto or manual
    mileage
    how long has it done this? any other symptoms? is there a check engine light? etc.
    edit: Changed my mind on my blind guess. From what I read of your post you said above 1/4 throttle it bogs or jumps and dies. I take it that means it is idling ok and running ok under light throttle (only a little gas pedal). My new blind guess is that you have a failing fuel pump that is not providing adequate pressure/volume for larger throttle angles. But provide more info and we can help you better, I'm really just shooting in the dark with my guesses.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
      could be a mass air if its a vortech, but who knows? guess we have to guess what vehicle he has... maybe its a Ford?
        If its got a carb, the jets should be cleaned. I had a similar problem with my Blazer except it bogged throughout the entire powerband.
