1994 olds achieva no spark
  • 1994 olds achieva no spark
    i have a 1994 oldmobile achieva and i have no spark i hooked up a scan tool to it and it said the crank sensor was bad! I relaced that and still nothing now i cant get a reading with any scan tool an dstill no spar what should i do???
    Which crank sensor did you replace? On a 3100, there are 2 - 1 behind the pulley and the other on the back side of the engine. The one on the back (which is a PITA to change) is the one that sends the signal to the ICM and therefore controls spark.
    By the way, welcome to the site!
      i replace the pita one lol i didnt know there were 2 of them
      but it will crank over and i had the coil pack tested and its good but still no spark
        Could be the ICM or the wiring from the CPS to the ICM.
        Droid via Tapatalk
          how do i check that? and where are those located? if you know
            ICM is the module that the coil packs mount to. The wire goes between that module and the crank sensor (CPS) that you replaced.
              k ill try that an see what happens if it wrks ill let you know thank you
                If your lighter doesn't work then your diagnostics port won't work. Check your fuses. I don't recall having a code for bad crank sensor...unless its for the one behind the harmonic balancer. What specific code was it? What kind of scanner are you using?
