3.4l starting problem?
  • Question : 3.4l starting problem?
    Alright so I am new here and have been trying to do some research to see if anyone can help me out here because I am at a loss so far. I have a 95 GTP and when starting in the mourning starts fine a good majority of the time but when starting any other time after that I have got to pedal the start as if it were carburated. Then when I do get it started after that I have got to crank it up to 1500 rpms for a while until it clears up. To go along with that issue the car idles rough until I drive it for a while then it clears up. Now I have already changed the idle air control and the intake manifold gaskets and am having no luck. Any suggestions?
    I have also recently changed the fuel pump.
      Have moved responses to your other thread in the DOHC Maintenance section. Welcome to the site! Hopefully we can help you get your problem fixed.
