My first post on a great forum. Pleae pardon the long explanation, but I have done a lot of work on this and want to make sure I put all important information out there. I am out of ideas and hoping for new direction.
I have a 3.4 P/R from a 95 Camaro that was a fresh rebuilt short block (rebuilt by someone else). Ran OK for 400 mi., then developed a knock. It wasn't constant - an irregular tapping, which occurred only at idle and when the motor was warm. Also had low oil pressure when the motor was warmed up.
I pulled the motor to check the bearing clearances and oil passages. The motor and oil inside was FILTHY. It was supposed to have been tanked and cleaned but I am guessing nobody ran a brush through the galleys. Bearing clearances were wide (.08') but within the tolerances I found listed for the motor. Only light scoring. I was thinking I had a clogged oil passage somewhere that caused the knock so I cleand it up and put it back in. Still had the knock.
Listened and poked around some more and decided that the sound was too deep for a lifter/valve and too light for a piston or bearing. I pulled the motor again. The timing chain was loose (supposedly new) and I could move the cam in/out enough that it would contact the block at idle - clunk. Under acceleration there was tension on the chain to pull it true. I'm thinking "I got it". Also was missing the timing chain guide.
I put a new roller chain set and chain guide on - nice and snug. Also installed a high volume oil pump while I was in there. Put it back in; now I have a continuous knock of the same pitch.
It could still be the cam floating, but I am running out of ideas. I don't have the veteran eye to spot the problem. I think I am just overlooking something. Maybe something that is used to hold the cam in place?
BTW oil pressure is still a little low at warm idle.
Could really use some advice.
Thanks,
Bob T.
Thanks,
Bob T.
