head gasket?
  • head gasket?
    i was changing the plugs on my little 4 banger in one of my rettas and i had to use alot of force to remove the number 4 plug.
    afterward i noticed that there was a green spot on the engine in that area, so i investigated and it was coolant.
    just wondering if someone could tell me if i could have messed up the head gasket using too much force getting the plug out
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    Doubt if you messed up a head gasket. Unless you are The Hulk. And I don't think the water jacket runs close enough to the plug hole to cause concern. Make sure you use anti-sieze on your plugs though. Hopefully you didn't strip the threads.
      yeah im just a little guy 110 lbs
      so i guess maybe i jsut didnt notice the leak before
      still think its the head gasket though
      its where the head meets the block that it appear to be comming from
      I Like V660s
      ~Jayme~
        Brother-in-law has the same problem on a 91 Berreta V-6. I get to tear it down next week. Lucky me. Can't charge relatives. He does buy the beer though.
