Help remove upper O2 sensor
  • Help remove upper O2 sensor
    I've soaked it with the best penatrate on the market while using the O2 sensor removal socket, and the upper O2 sensor on my monte 3.1 won't budge. I can't get a pipe wrench around it. There's plenty of room to work with it cause i'm replaceing the head gaskets. Suggestions welcome....Tom
    Run it and get it Hot, this will help out.
    You will need to have a tap ready for the pipe, as the threads will be messed up upon removal.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
      On mine, I stuck 1/2" extensions up to where I could get a breaker bar on it. The bar was bending and then it broke free, threads were ok thank god... LMAO I soaked it in PB Blaster for a couple nights. Soaking it good each day...
      Using an impact gun might actually be better and help.... Less chance of breaking a tool or the manifold/O2 sensor/socket... The sudden shock/jarring of the impact breaks free rust...
        mix ATF and acetone at a 50/50 mixture. that stuff works wonders for breaking through rust.
          Thanks. Thing i'll soak'er real good for a while, heat'er up a little with a torch..... Tom
            Chase the threads before installing the new o2 , I wrecked a wideband by not doing that.
              Will chase the threads before reinstalling O2..........Tom
