Gasket Part Numbers
  • Gasket Part Numbers
    Hmmmm My Search queries coming up blank (probably need more coffee lol)
    Looking for the Part numbers the gaskets for the LIM and UIM & Rockers Covers (metal LIM) for the 3500 LX9?
    Also for the Timing Cover (can remember which is better, Brown?? )
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    My Supplier has Felpro MS9013T(Kit has LIM/UIM and RockerCover Gaskets) listed, he says is the new Update but does not know if it is metal or not?????
    Also, can't find the post I read about Front Cover gasket, about Black and Brown?
    Which is better? (Think I read Brown? )
    Anyone have the PN for that?
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      yep its the metal ones. same ones i bought before.
      FEL-PRO Part # MS98013T More Info {Intake Manifold Gasket Set}
      OHV engine; Valve cover gskts. & Upper set incl.; PermaDryPlus® int. manifold gskts. incl.
      do you mean the timing cover gasket. last time around i used the fel pro one. iirc you get the water pump and a few other gaskets in the set with that.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        Awsome, thanx,
        Now just have to find the best Front Cover gasket and I am all set lol.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
          5.08 from rock auto
          FEL-PRO Part # TCS45828 More Info
          OHV engine; w/o Sleeve 'N' Seal
          99 Grand Am GT
            Ahhhh, My guy find that number, he only lists TCS46088
            Wonder if its a Canadian Thang lol?
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
              well yeah that will work its the set for the 3500
              the one i posted was for the 3400
              99 Grand Am GT
                Cool, thanx, just wanted to be sure!
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
