a way to burp the cooling system on a 3500?
  • a way to burp the cooling system on a 3500?
    burping the coolant system on a fiero is always a must. and difficult on a motor swap. is there any good way to successfully burp the fiero coolant system with a 3500? it looks as if it would be the same as a 3400 from the ones ive seen at the junkyard
    ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
    87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
    im not too familiar with 3x00 swaps in fieros, but doesnt your 3500 have a bleeder on the thermostat housing??
    [SIGPIC]
    12.268@117... 11's to come!
      it has some kind of nipple thing on the thermo neck. i didnt do the swap, so i dont know what that is. my brother did and its hard to get ahold of him now that hes busy doing REAL military stuff in WA.
        On the thermostat neck, there should be one. Also on the top of the water pump there is one on top of the black pipe. Wait till the engine is hot enough for the thermostat to open, then open those up, and rev it a bit (I've found that helps push out stuck air) and then close them while the coolant is flowing out.
          that sounds good to me. also sounds like a 2 person job, so ill have a friend help me
            2 person? how? throttle is easy enough to play with underhood...
              Nah not that bad. On mine, I have a thermo neck with a metal pipe that goes to the coolant overflow tank. Some don't have this. I thought about swapping to the style with just a bleeder but never did.
                i dont wanna burn myself when the engine is heated up. im not fire or boiling proof. i burn easy.
                  !!! Haha you'll be fine... I think any human burns easy... lol
                    yep, just let it warm up and open that bleeder on the water pump tower till straight coolant comes out.
                    you may have to do it a few times
                      Funny thing is, I've only opened that bleeder when I fill my cooling system... I close it once coolant starts to come out... I've never warmed up the car and then opened up that bleeder, and I've never had any cooling troubles either.
                      I also opened the one on the thermo neck since I have that now instead of that extra cross over tube to the tank.
                        What about a 3.4 ?
                          so i had a coolant leak. lost about a gallon O_O im trying to figure out where to fill this back up at. i put some in the radiator, and with the engine cold, forcing some in into that thermo neck bleeder. im thinking when the thermo opens, it will start sucking the coolant from hte bottle rig i have. am i doing it right or am i going to cause some catastrophic meltdown and end life as we know it? i sure hope i dont go too far with doing it the wrong way if i am lol.
