Exhaust manifold leaks
  • Question : Exhaust manifold leaks
    Would a leak in the exhaust before the O2 sensor cause lean readings and sluggish performance?
    After installing a WBO2 (innovate LC-1), I consistantly see ~16:1 afr's at idle and part throttle acceleration. It sticks to that untill I go WOT and I'll see around 13.5:1. On start-up I see 11:1 for a several seconds and then it will go back to 16:1. I'm also leaning towards a bad FPR being the cause.
    1995 Grand Am SE
    Yes. Any leak pre O2 will screw with readings pretty bad.
      exact reason why you shouldn't trust the dyno WBo2...
